What should i do while my engine is out?
Old Aug 31, 2009 | 04:04 PM
NanaimoCTT's Avatar
NanaimoCTT is infamous around these parts
I'm dropping the engine out of my 04 CTT to change the coolant pipes and change a turbo seal and the damn howling noise from the alternator. So what else should I do while the motor is out? The car has 55K mile on it
Old Aug 31, 2009 | 08:20 PM
huskyfan23's Avatar
huskyfan23 is infamous around these parts
Port the heads and throw on bigger turbos
Old Aug 31, 2009 | 08:58 PM
knicks's Avatar
knicks is infamous around these parts
headers!
then take a picture of you in the engine bay
Old Aug 31, 2009 | 11:04 PM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
FYI..You don't have to pull your motor to change the coolant pipes.
Old Aug 31, 2009 | 11:11 PM
knicks's Avatar
he has to change turbo seal too, if you have to pull the motor for that
Old Aug 31, 2009 | 11:31 PM
NanaimoCTT's Avatar
i might also change the tranny hydraulic valve. the harsh shifting from 5th to 4th is annoying me!!
Old Sep 1, 2009 | 02:52 AM
ONE234's Avatar
ONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud of
give it a dam good clean.
while you have the chance.
not sure why you have taken the engine out for those repairs though? they can both be done with the engine in situ.
Old Sep 1, 2009 | 11:07 AM
NanaimoCTT's Avatar
you have to take the motor out to get to the turbos
Jul 29, 2019 11:13 AM
saline
Oct 7, 2015 07:29 AM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
