Leaking roof drains
I'm having the same problem on my '08 Cayenne GTS. During a constant rain water somehow works its way onto the drivers side rear air bag canister in the hatch pillar. I am unable to trace water to its source as it appears to be coming from a body seam. Any suggestions? Drain, roof rail, . . . ? Thanks
I'd suggest taking the pillar covers off and place a water hose on things from the outside to see where it's seeping in. Or if you have a second person there, you can see the channels to the drain with the sunroof open and place the hose there (flowing very slowly) and then you'll know for sure if it's the drain. On the original leak I had the headliner didn't get wet where I could see it, necessarily. The water would flow over it without soaking through.
Reviving this old thread here... My car was broken into, whole pano roof was replaced by the dealership. Fast forward about 6 weeks, I opened my spare tire area this morning and water everywhere! I'm assuming this is the same issue, but unlike you guys I don't have any water/moisture on my pillars or in the hatch area, only under where the spare tire & air compressor are. I should be able to take this back to the dealership, correct?
I would think so. The headliner and covers have a coating that resists some water. If it's a slow leak or something that's short in duration then it may not show right away.
Yea I called Porsche NA, they contacted the dealership that did the work (NJ), and also told me I could take it to any dealer since I no longer live there (now in Dallas TX). The NJ dealer has contacted me and told me to take the truck in to a local Dallas dealership and they would come to a "settlement" on the matter, since I had aftermarket JL amps and amp/sub wiring all through that compartment under the spare tire. I don't know what they mean by "settlement", but all I want is everything fixed, we'll see how this goes!
ECS Tuning - VW
Sep 30, 2015 12:21 PM
