transfer box differenece on cayenne /s and turbo
Old Dec 30, 2009 | 06:22 PM
mtimmy415's Avatar
mtimmy415 is infamous around these parts
Do you guys knows if there is a difference between the transfer box from a cayenne to a cayenne s and a turbo,
my transfer box needed to be replace and would like to know if a reman or a used one from a regular cayenne or v8 would fit on my turbo
Old Jan 3, 2010 | 01:56 PM
jsc1m3's Avatar
jsc1m3 is infamous around these parts
Hello, I'm a Porsche tech and just wanted chime in on this one. It's pretty un-common to see the whole transfer case need replaced. 1.have you checked to see if the recall needs done (there is two different recall's one for the whole case and one for the transfer case motor) 2.If you do need a case then there is no difference between the s and the turbo, the v6 transfer case is different. 3.Depending on the year and mileage you might try and contact Porsche for assistance. hope this is helpful
Old Jan 5, 2010 | 02:55 AM
mtimmy415's Avatar
thanks for your reply., Yes., my transfer case needed to be replace due to some stupid act done by my friend...
I have a 04 turbo so... I can source a transfer case from a S and it will fit? I assume within the first gen right
Old Jan 5, 2010 | 04:27 PM
knicks's Avatar
knicks is infamous around these parts
sorry to hear your friend did it.
i think there was a thread on this not to long ago, and if i remember correctly, the transfer box is the same on the s and turbo, while the v6 is different. so im 90% sure you can just pick one up from an S and itll be fine
Old Jan 6, 2010 | 07:37 AM
canberk's Avatar
canberk is infamous around these parts
what did your friend do to damage the box?
Old Dec 20, 2021 | 03:38 PM
Anas's Avatar
Anas is infamous around these parts
2008 transfer case
Can i use a rurbo s transfercase for v6 model
Oct 6, 2015 05:20 AM
Aug 21, 2015 09:56 AM
Aug 21, 2015 06:34 AM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
