Turn marker
Old Feb 9, 2010 | 04:54 PM
ikold's Avatar
ikold is infamous around these parts
Turn marker
The other day the a warning went off saying my right turn side light was out. Anyone know where I can order one of these, and how much they run?
Seems like an odd light to go out...
Also what is everyone using for oil change intervals on the Turbo ?
Old Feb 10, 2010 | 11:33 AM
medtech's Avatar
medtech is infamous around these parts
Both my 06s had this issue.
Old Feb 10, 2010 | 04:29 PM
hulahula's Avatar
hulahula is infamous around these parts
Had similar problems with my 05 CTT. Just a bit of corrosion in the connector. Replaced under warranty. Also, check to make sure the headlight is locked in correctly. Should crank down and lock in with a "crack" or "pop".
Oil changes every 10k.
Old Feb 16, 2010 | 04:28 PM
ikold's Avatar
Where can I order the light ? is it just a bulb that needs replacing.
J
Old Feb 16, 2010 | 04:45 PM
NioElva's Avatar
NioElva is infamous around these parts
It is probably just the bulb. Check your owners manual for which type of bulb it is and buy one at your local carparts dealer.
S
Risley
Sep 19, 2015 01:22 PM
dailydriver
Sep 13, 2015 09:01 AM
su_maverick
Sep 8, 2015 11:12 AM
