Cayenne Drivers side window
Old May 4, 2010 | 11:13 AM
liftsheavy's Avatar
liftsheavy is infamous around these parts
The Drivers side window on my 2004 Cayenne Turbo stopped working. I took off the panel and pulled back the sub-panel The motor seems to be working fine but the cable coming out of the top of the motor is hanging loose, unattached. Where does this cable connect to? How far can I pull the sub-panel away without damaging it or without popping the rivets? Thanks for your help and taking the time to respond.
Old May 4, 2010 | 04:29 PM
liftsheavy's Avatar
Further Apart
I took the motor off and the cable was all bent up around where it connects to the wheel. I need A new cable. Can I order this online?
Old May 4, 2010 | 04:40 PM
pcst's Avatar
pcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the rough
Dang,,, dealing with broken window hardware isn't existing for sure. I would call Luke & Sunset Imports to figure out the part# on that bad boy.
Good luck!
Old May 4, 2010 | 06:51 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
At that point, if the cable has come out, you might need a new window regulator.
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
tkeck3
Aug 25, 2015 02:52 PM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 23, 2015 07:36 PM
