Cayenne Hybrid "Sailing" mode
Old May 28, 2010 | 02:08 AM
TheAMV8's Avatar
TheAMV8 is infamous around these parts
Here is an interesting question that just occurred to me: apparently the Cayenne Hybrid will go into "sailing mode" when you take your foot off the gas pedal. In this mode it not only shuts down the gas engine, but also disengages the engine driveshaft and essentially coasts - great for fuel economy
But oftentimes when you're descending a snow covered or slick road it is useful to downshift and use engine breaking to keep control of the vehicle versus using the breaks
So how does this work in the hybrid? Does it always engage the engine if you put the transmission into manual shift mode? Or are you out of luck I.e. Have to rely on braking alone?
Having just ordered a hybrid, I'm beginning to get cold feet and am starting to lean towards the turbo!
Old May 28, 2010 | 12:42 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
On my Lexus gs450h when I downshift the cvt engine it does gear down in a way. Able to "engine break" if you will still.
Old May 30, 2010 | 01:51 PM
Gfunk's Avatar
Gfunk is infamous around these parts
I have a Pruis, and and you can put it into engine braking mode. I'm sure the Cayenne will have the same for offroading purposes.
Old Dec 18, 2013 | 08:01 AM
DoctorWill's Avatar
DoctorWill is infamous around these parts
Hi, I just picked up a 2013 Cayenne hybrid. How do I engage in the sailing mode?
Old Dec 18, 2013 | 08:13 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
You've just got to be at a speed between 30 and 97 mph (not in Sport mode) and take your foot fully off the accelerator pedal. If you're on a downhill gradient greater than 4%, it also won't coast, but will begin recuperation for the high-voltage battery which will slow the vehicle.
Old Dec 18, 2013 | 08:21 AM
DoctorWill's Avatar
I see. Just tried it out! I wonder why it doesn't use the battery to maintain the speed? For example, if the battery is full and I am on cruise control.
NC 996TT
Mar 23, 2023 06:19 AM
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
smartbot
May 16, 2016 12:35 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
