Fabspeed Bypass and EVOMSit Tune
Old Sep 24, 2010 | 02:27 PM
Bean Counter's Avatar
Bean Counter is infamous around these parts
Thumbs up Fabspeed Bypass and EVOMSit Tune
I wanted to post a thank you to the guys at Fabspeed for getting my secondary cat bypasses and EVOMSit CPU tune done today.
I had previously installed Evoms v-flow intake and new plenum. With these two new additions my 05 Cayenne TT is now scary fun. The ride back from Fabspeed on the PA Turnpike was a blast.
Keep up the great work Fabspeed.
Lowering module is on it's way. Next is a body kit. Anyone know a good body kit installer in the greater Philly area?
Bean Counter
Old Sep 24, 2010 | 05:35 PM
kcphuah's Avatar
kcphuah is infamous around these partskcphuah is infamous around these parts
Can you describe how big of a difference do you feel? I have a 08 TT and thinking of doing the EVOM tune, by pass pipe, V flow and IPD Plenum.
Old Sep 24, 2010 | 05:57 PM
Difference
It feels very significant. Perhaps more so at higher speeds than lower speeds. The plenum had a notable difference. The intakes felt like a moderate improvement but the sound they make is addicting.
I did the chip tune and bypasses at the same time so I can only speak about them together. The sounds from the bypass is very nice. Once you take off PSM (05 turbo in my case) the car takes off like a bullet.
The acceleration at low speeds in fantastic but at high speeds is just ridiculous.
I highly recommend the mods.
Old Sep 25, 2010 | 07:27 AM
CayenneTurbo77's Avatar
CayenneTurbo77 has a spectacular aura aboutCayenneTurbo77 has a spectacular aura about
Bean Counter
These are the only guys I trust with my cars, Porsche of the main line uses them also.
http://www.cavalloautobody.com/
Old Sep 25, 2010 | 10:02 AM
rgibson's Avatar
rgibson is infamous around these parts
Probably a silly question but I assume the chip tune will void the warrantee on a 2008/2009 model. Can it be removed when taking the car in for service? If so, does it leave any traces behind that they could use as grounds to deny warrantee work?
Old Sep 25, 2010 | 12:44 PM
PianoProdigy's Avatar
PianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud of
I'm planning on doing the tune, cat bypass pipes and intakes. Think the plenum is worth the extra $900?
Old Sep 25, 2010 | 07:55 PM
Nasser's Avatar
Nasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant future
any clips
Old Sep 25, 2010 | 09:00 PM
Babag 007's Avatar
Babag 007 is infamous around these partsBabag 007 is infamous around these parts
Just had my 08' TT done at fabspeed as well. I wholly agree with Bean Counter; transformed a fast car into a veritable beast! Love it and more addictive than any drug.
Fabspeed represented no warranty void. No tell tale sign documenting ECU remapping. If the dealership believes there is an issue, Fabspeed will remap back.
I must say, I wouldn't ever go back to pre ECU, cat-back exhaust and smaller intercoolers. It would be like dating a supermodel, and then having to date your sister. Nothing against your sister
Seriously, it's worth the $.
Jun 10, 2017 07:45 PM
cby1
Sep 1, 2015 10:25 AM
metzkaro
Aug 30, 2015 10:22 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
