Location of Compass Module???
Old Nov 5, 2010 | 03:42 PM
snzuloz's Avatar
snzuloz is infamous around these parts
Originally Posted by porschetech
if you have pcm 2.0 you have nav which works via cd. pcm 2.1 works via dvd and has a seperate player which sits under the passenger seat. pcm 2.0 vehicles have a storage drawer under the seat. here's the link to explain extended nav. its enabled via the dealer using the piwis tester. software is @ $200
http://www.porsche.com/usa/accessori...igationmodule/
Thanks for the information! Much appreciated.
Old Nov 5, 2010 | 05:45 PM
porschetech's Avatar
porschetech is infamous around these parts
Originally Posted by carreracup03
I have a 2005 CTT with 2.1 PCM with DVD. I did not have the compass on the left hand side of speedo. I upgraded to a new pcm with the phone buttons, as my old one did not have them, and I wanted to get mobridge.
WHen I got my new to me, used PCM and hooked it up ... the compass was there on the dash. I think the new pcm had the programing.
yeah i think the later pcm 2.1 units had that compass software pre-installed
Old Nov 6, 2010 | 01:52 PM
CBRacerX's Avatar
CBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to behold
I should be so lucky
Now I am looking at making a harness for the compass module. Anyone have a line on where to to get the connector for this?
Old Nov 9, 2010 | 12:01 AM
i'll still look into this a bit more. from what i gather pcm 2.1 displays the compass on the cluster.
edit/update.......just looked at an 06 cayenne 's' with pcm 2.1. it has compass on the cluster and no magnetic field sensor under the rear seat. so yeah you need the software from porsche and then you need to go to your local dealer and get them to enable 'compass' in the pcm
Old Nov 12, 2010 | 07:59 AM
CBRacerX's Avatar
I guess I have a sensor and bracket for sale then!!
Old Nov 12, 2010 | 06:14 PM
gr8ful's Avatar
gr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to all
I have the display on mine, however, it is my understanding that there is an optional compass that allows for very fine adjustments to accomodate different magnetic areas of the world. Isn't there a standard one like mine and a more sophisticated one?
Old Nov 13, 2010 | 12:07 AM
hmmm......tempting. i don't know if i'd be happy to splice into the CAN wiring. perhaps i'll just wait until a PCM 2.1 comes up for sale. i already have the dvd nav drive
Old Nov 13, 2010 | 06:16 AM
CBRacerX's Avatar
Take a look, you might have the harness in place now.
adnanm3
Nov 22, 2023 02:43 AM
Rguy
Apr 12, 2020 11:11 PM
dgreen78
Feb 29, 2016 11:28 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
