Im Very confused about my Brake Pads. 08 Turbo 368mm Rotors
Old Nov 18, 2010 | 04:11 PM
gekogustin's Avatar
gekogustin is infamous around these parts
Unhappy Im Very confused about my Brake Pads. 08 Turbo 368mm Rotors
Hi , Im very confused about my brake pads, y try to find it in the Hawk page but said me that brake pads are for the 350mm rotors, some one can help me , here in mexico the pads cost 32000 pesos about 2600USD whit porsche dealer, yes its ridiculos,every help will be apreciated. Thanks
I measured the Rotors 368MM I have Red Calipers and 19Wheels
Cayenne Turbo 08
Old Nov 18, 2010 | 04:23 PM
snzuloz's Avatar
snzuloz is infamous around these parts
From what I could locate on Hawks site the Turbo and the GTS use the same part number. Maybe the pad size remains the same (caliper is the same for both) and they just utilize a slightly larger rotor with a different caliper mounting bracket for your application?
Old Nov 19, 2010 | 07:03 AM
spinny02's Avatar
spinny02 is infamous around these parts
Funny I did not see your post! I just posted the same thing. I am also having the same problem . Hawk is saying they don't make pads for us.
Old Nov 19, 2010 | 11:43 AM
gekogustin's Avatar
Smile Finally Found
Hi I finaly find the brake pads from http://www.aboveallmotorwerks.com guys the correct part No is
TEXTAR 95535293963_S REAR PADS
TEXTAR 95535193963_S FRONT PADS
They have the orignal porshe pads too.(i really think
This is the corect Pads For the 368mm front rotors and 358mm Rear Rotor.
Europe Name: Brake 18+Plus
The Brakes are the R50. Its brakes can fie in Cayenne , touraeg and Q7.
Thanks to all.
TEXTAR_95535193963_
TEXTAR_95535193963_S
TEXTAR_95535193963_
GENUINE PORSCHE Brake Pad Hardware Kit (Mounting Parts) Front (1 Needed Per Car) Contains: (2) Retaining Pins (2) Spring Clips (2) Lock Bolts
$17.85**
$17.85
TEXTAR_95535293963_S
TEXTAR Brake Pad Set Rear NOTE: For Spring Clips Use (2) 955 352 959 10
$175.20**
$175.20
TEXTAR Brake Pad Set Front NOTE: For Mounting Parts Use (1) 955 351 959 10 kit
$149.70**
Old Nov 19, 2010 | 11:45 AM
gekogustin's Avatar
chek the post I find the correct Pad
2lflat4
Nov 18, 2019 05:05 PM
awchristler
Bentley
Aug 24, 2015 03:53 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
TrackOne
Aug 20, 2015 12:56 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
