Comfort vs Normal Ride Setting ?
Old Jan 4, 2011 | 10:19 AM
RobsCountach's Avatar
RobsCountach is infamous around these parts
Hello All;
Well, I just read that 20 page dissertation on lowering tricks, but now have a concern.
I find NO difference between Comfort and Normal; both seem a little harsh to me. My dash has no errors and in fact; it says 'where' the setting is while the vehicle goes up/down...and when done.
Now, I do drive in the lowest (non-mod allowable) setting. 2nd from lowest.
Is that why ?
Oh, I have navigation, but there's a Fire Extinguisher under there with the air valve. No CD/DVD... I've got different wires ???
Old Jan 4, 2011 | 10:28 AM
canberk's Avatar
canberk is infamous around these parts
hi,
2004 cayenne does not have a DVD navigation therefore it is normal that you don't have a dvd reader under the passenger seat. You have the CD navigation if you have the PCM, and you need to insert the map CD to the slot on the PCM in order to use it.
About the ride stiffness, I also don't notice a big difference between the normal and comfort on the highway but if you actually drive on a bad road with pot holes on it, you can notice the difference between the modes if you concentrate on it. There is also a big chance that your car's shocks are old too.
One other note, the higher you set the car's level, the stiffer the ride will get.
Old Jan 4, 2011 | 10:40 AM
Hi Canberk;
Thanks for the response. It does help !
However, did you mean the 'lower' I set my suspension the stiffer the ride?
We must follow the same path, I've had a Masi GT in the past as well. They are wonderful cars...better than the Ferrari's that build them - IMO.
Originally Posted by canberk
hi,
Old Jan 4, 2011 | 10:52 AM
canberk's Avatar
haha yeah, maserati is definitely worth the money vs ferrari.
with air suspensions, if you increase the height level, you will jump more, therefore the ride will be less comfortable. try driving over some speed bumps with different level settings, you'll see what i'm trying to say. The lower the car is, the more comfortable it is. However, if you use the lowering modules to drive in the lowest setting, i noticed that the ride gets less comfortable again. So, Porsche allowed lowest height with the comfort setting will give you the smoothest ride
ECS Tuning - VW
Aug 25, 2015 02:54 PM
tkeck3
Aug 25, 2015 02:52 PM
pwdrhound
Aug 20, 2015 05:54 AM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 18, 2015 01:04 PM
