Is it safe to use wheel adapters on Cayenne?
Old Apr 26, 2011 | 01:51 PM
profusion's Avatar
profusion is infamous around these parts
I found a set of 22s that I like but the wheels have a 5x112 pattern. Will it be safe to use an adapter to make it fit my 05 Cayenne S? Im not sure if vibrations will be an issue. Thanks!
Old Apr 26, 2011 | 03:33 PM
damon@tirerack's Avatar
Moderator
I good adapter may not vibrate, but may wear drivetrain components over time. You'll have to have a pretty large offset over the already large offset the Cayenne takes in order to clear the hub and adapter and still fit. I doubt it does. 22 x 10 55mm ET is standard fit. The wheel is going to have to have probably 80+mm to fit, and I really doubt it does. Find out the offset of the wheel. If it's less than 70mm, pass because you will just chase your tail to make it fit.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Apr 26, 2011 | 09:49 PM
pnwpirelli's Avatar
pnwpirelli is infamous around these parts
ALL Porsches are 5x130 - PLEASE do not do this. Just stick with something that fits.
Old Apr 27, 2011 | 11:09 AM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
you jersey guys.......ha ha
albert@velosdesignwerks
Cayenne
Aug 28, 2015 06:36 PM
The Oss
Aug 24, 2015 08:19 PM
Cayenne 958
Aug 19, 2015 02:43 PM
