Sloshing sound when cornering or driving on hills
Old Oct 26, 2011 | 04:16 PM
mjb2503's Avatar
mjb2503 is infamous around these parts
I've just started to notice that when I corner or drive up or down hill, particularly just after start up, there's a fairly loud sloshing sound, like a lot of liquid shifting around. Am I being dumb and it's just gas in the tank, or could it be something else?! I hadn't noticed it until late and want to make sure it's not anything more serious!
Old Oct 26, 2011 | 04:48 PM
Dennis C's Avatar
Where do you hear the sound? Cayennes can collect water in a few undesirable places. The most common ones are in the rear of the vehicle. One is inside the rear spoiler above the back window. The other is inside the spare tire/subwoofer compartment under the rear floor.
Old Oct 26, 2011 | 04:57 PM
mjb2503's Avatar
That doesn't sound good! It's definitely coming from the back, sounds lower rather than higher too. What's the best way to access the two areas to be sure? Any thoughts on how to empty the two areas if they're the issue?
Old Oct 26, 2011 | 05:02 PM
Loutorious's Avatar
Loutorious is infamous around these parts
If the rear areas mentioned are dry, you may want to check the rocker areas (no sure the correct term, the length of metal frame under doors). I unplugged 2 rubber plugs on driver side and about 1 - 2 gallons of water poured out. Mine was bad even the carpet was wet. I still have not had a chance to find the cause, but probably drainage problem from the windshield area leading to behind wheelwell liner. That sloshing sound was driving me nuts... every stop and go... every traffic light... and is NYC
Old Oct 26, 2011 | 06:13 PM
Dennis C's Avatar
I think the sunroof drains can get clogged and cause this problem.
I haven't tried to access the area under the spoiler cover, so I can't help you with this one. For the spare tire area, you should be able to simply lift up the cover in the back and look. I'm not sure how to drain it, but if it is full that will give you some idea of where to start looking to find the problem.
Old Oct 26, 2011 | 06:18 PM
mjb2503's Avatar
Thanks Dennis, I'll let you know what I find, wish me luck!
Old Oct 29, 2011 | 11:44 AM
mjb2503's Avatar
It was the drains at the side of the engine bay. Took my local Porsche dealer about 30 minutes to fix the issue and they waved the charge for the second time in 6 weeks, such good service!
Old Oct 29, 2011 | 04:29 PM
Dennis C's Avatar
Nice!
audipwr1
Sep 25, 2021 01:31 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
