Drive Shaft Replacement Kit
Old Nov 22, 2011 | 08:17 AM
chanes5's Avatar
chanes5 is infamous around these parts
Has anyone tried this kit http://www.vertexauto.com/ShowItem/293811%20Porsche%20Cayenne%20Drive%20Shaft%20Repai r%20Bearing%20Support.aspx
Says it replaces old bearring in 30 min. Thinking of replacing mine soon, let me know what you guys think!
Old Nov 24, 2011 | 12:14 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Been discussed at some length on this and other Cayenne forums.
Since it doesn't replace the bearing - if the bearing is the problem (and a seizing bearing WILL tear the rubber support) - it's a wasted effort.
One person did buy it and try it - and removed it rather quickly. He said it caused vibration in the car that he could feel. He ended up with a new or rebuilt driveshaft.
Since the rebuilt shaft from the same vendor is LESS money then this kit - and since the shaft can be easily replaced (probably in the same 30 minutes to do the bearing) it seems like a solution for a question no one asked..
I'd just go with a rebuilt driveshaft.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
vr6tee
Aug 29, 2015 03:52 AM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
