Oil Leak / Vacuum Leak : Does anyone know what part this is?
You can source the membrane here.
http://vanos-bmw.com/membrane-948105...enne-45l-450ps
Or here.
http://www.ebay.com.au/itm/181341946441?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Or here.
Pelican parts sells the diaphragm and gives a how-to as well. Click the link for the entire write-up and part.
http://www.pelicanparts.com/techarti..._Separator.htm
The 948-105-934-00 that's quoted in the article is not the correct part number either. That is the camshaft adjuster seal.
There doesn't seem to be a correct diaphragm part number listed.
Oil consumption will vary based on how hard the engine works. If you’re running in sports mode frequently expect to add oil more frequently. If I recall correctly, I may need to add a quart after 4000 to 5000 miles.
04-28-2022 12:38 AM
