DIY brake flush
Old Feb 3, 2012 | 09:57 AM
intheflesh's Avatar
intheflesh has a spectacular aura aboutintheflesh has a spectacular aura aboutintheflesh has a spectacular aura about
DIY brake flush
Doing my rear brakes and rotors, and also a flush this weekend. I did my Frits recently, so I am familiar with the pad and rotor procedure. And yes I do have the special triple square bit for the rear rotors.
Now for the flush.... Per the suggestion of renntech, I'm going to use ate 200 fluid. The master cylinder is located drivers side front, correct? So I would want to go Passenger rear, driver rear, passenger front, driver front; correct? Anything special I should know before attacking this project?
Old Feb 3, 2012 | 09:59 AM
intheflesh's Avatar
Also, how much fluid do you think I would need? 2 liters should be enough, right?
Old Feb 3, 2012 | 10:29 AM
trunkmonkey's Avatar
trunkmonkey is a jewel in the roughtrunkmonkey is a jewel in the roughtrunkmonkey is a jewel in the rough
Just on can of the ATE 200 is needed, the order is to to furthest to closest so passenger rear, driver rear, passenger front driver front.
Old Feb 3, 2012 | 11:12 AM
intheflesh's Avatar
thanks for the tip.
does anyone know the torque specs for the mounting bolts, etc?
i did a quick search, but came up with nothing
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
