Remove Sound Level Compensation Feature?
Old Feb 6, 2012 | 09:52 AM
silvercayenneS's Avatar
silvercayenneS is infamous around these parts
Disable Bose Noise Compensation Feature?
I find the Bose noise compensation feature, which increases and reduces the sound system volume when the car speeds up and slows down, to be very annoying. When I set the volume set at a normal listening level while driving, the sound system reduces the volume to an almost imperceptible level when the car slows down and stops, at a stop sign for instance. I find myself constantly fiddling with the volume controls to maintain the same volume.
Is there a way to disable or disconnect this feature in the settings, or directly on the amp? Here is a picture that shows that the feature is located in the amp, but the settings may exist on the audio menu screen.
Old Feb 6, 2012 | 12:00 PM
vishal's Avatar
vishal is infamous around these parts
In the Audio settings section (I think under the 'Sound' button), one of the last options is "AudioPilot" - uncheck this box. I also disabled this when I had the PCM in my car, I found it very annoying and too sensitive.
Old Feb 9, 2012 | 12:06 PM
Thanks!
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
Aug 19, 2015 06:35 PM
