Blinder Laser Jammer Install: Where to tap 12v and/or ignition.
I am about to install my laser jammers but havent looked under the driver area yet. Anyone have some quick knowledge about where to tap into for the 12v, or the ignition cable...
Drivers side. Open the door. There is a large panel right there on the side of the dash. Read your fuse locations in your manual, find one that turns on with ignition. Tap into the fuse box with a fuse tap available at any auto parts store. Its basically a fuse wedge that goes into an existing fuse and then you add two of the same amp fuses to the tap. Very easy to do. Then just find a ground.
Ok picture did not work. Type in fuse tap into google and hit images
alpha motoring
Oct 2, 2015 12:04 PM
