Anyone replace a front half shaft? Ripped CV Boot
Old Sep 2, 2012 | 07:16 PM
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
I was under my 05 Cs this weekend replacing pad and I noticed my LF inner CV boot was ripped. There was still grease in it, but some had spun out already. No noise, no sign of failure, just a ripped boot. Has anyone here pulled a Cayenne half shaft before? Is it:
> Tie rod / lower ball joint disconnect
> Shaft nut and then push (as in - bang with a sledge while the nut is on but cracked loose) the axel through the outer hub
> swing the suspension assembly out of the way
> Unbolt shaft from trany
> Remove shaft, replace boot (using cone method) or entire shaft
> Reassemble
Did I miss a step? Will I have to pound the #*&$^^@# out of the outer end of the axel shaft to get the shaft lose from the hub? Will I need a special press? Will the trany fluid drain when I unbolt the inner axel?
If the pita factor is too high I will just bring it to my buddies shop.
It sucks that a $5 rubber boot can be such a ***** to get at !!! Where is a universal "replace on car" boot when you need one !
Enemy
Nov 10, 2015 08:01 AM
vr6tee
Aug 29, 2015 03:52 AM
gulf gt
Aug 27, 2015 10:27 AM
Jeff1smith
Aug 19, 2015 09:41 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
