Secondary bypass pipes install?
Old Sep 17, 2012 | 09:34 AM
underpressure02's Avatar
underpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond repute
So last night I threw my 06 cayenne turbo s on the lift to put the bypass pipes on and of course all the nuts and bolts were rusted so most of them just broke right off. My question is on the passenger side the top bolt is pretty hard to get to. Is there any tricks to get to that and easily remove it? I am going to do that side today after work but figured I would ask.
TIA
Old Sep 17, 2012 | 12:05 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Yes- use a flex head, ratcheting, closed-ended wrench. Like this:
Also soak it for a few hours with your favorite penetrate oil. I use PB Blaster. You can also bend the bottom of the primary cat flange (since it has a flex connector) to get a little more clearance to work with.
FWIW, I believe the Porsche service manual recommends that that nut is removed from the top by using alot of extensions to get to that area from the engine bay.
I liked my way better from the bottom.
Old Sep 17, 2012 | 02:07 PM
I was looking to see if I could get it from the top last night but wasn't sure if I could actually get on it. Hopefully I have a flex head in that size.
Old Sep 17, 2012 | 02:18 PM
Moderator
If memory serves, I believe it is a 13mm. Just had to pull mine a couple of weekends ago.
Good Luck.
Jun 10, 2017 07:45 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
Aug 20, 2015 12:17 PM
