Lowering Module and unplugging battery
my car has a lowering module installed. However I have had the battery pulled for the last week and a half to do the cooling system. Today I put everything back together and start it up and getting a air system malfunction error. Is this because the air suspension reset itself and needs to be reprogrammed?
If it happened immediately after pulling the battery, I would say that it is probably not a coincidence. So I would assume that the lowering module needs to be reprogrammed.
If you have a Durametric you can re-calibrate the air suspension yourself. I already typed up some basic instructions and was planning on putting up a tutorial on this forum with some pics. Let me know if you want to give those instructions a shot and I will PM them to you,
adnanm3
Nov 22, 2023 02:43 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
gadgetman
Sep 10, 2015 03:29 PM
