Check engine light- Wrong fuel?
Old Nov 14, 2012 | 05:28 AM
Hal 2000's Avatar
Hal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really nice
My 06S just got the check engine light lit on the tach. I have no other warnings and no messages on the osd. Car runs great.
We had a gas shortage after Hurricane Sandy, and my wife added a half tank of regular to the half tank of super in the car. Only fuel available.
I added 1/4 tank of Super this morning, Light is still lit. Gas cap is tight.
This happened when temp. outside hit 34 degrees for the first time this year. I may have the original battery, not sure if original owner changed it. No other problems at all. I expected more Gremlins if the battery was bad.
Wife said car beeped and headlights did not go off in auto mode?
Can't check codes, want to stay away from the stealership.
Could this just be a routine maintenance light?
Old Nov 15, 2012 | 12:25 PM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
No its not a routine maintenence light. The only real way to tell is to get the codes scanned. You don't have to go to the stealership either. Autozone scans for free. If the battery was the problem you would see a picture of a battery when you first start the car on the center diplay with the gauges. It could be a bazillion things, go get it scanned and report back.
Old Nov 15, 2012 | 01:50 PM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Wink
I was just out in NJ the days after the hurricane. I towed home a Eurovan with the CTT.
I definitely got a bad tank of gas somewhere out there. Got a check engine light for a couple of hundred miles and then it cleared itself. Hasn't been back since.
Technically, if you read the owners manual its an "emissions system" related light and the manual even warns about certain types of fuel causing the issue. (Does anyone but me actually read the owners manual around here?)
It will come on for other issues too. Unless its flashing, it's not critical. So drive it a few days and see if it clears. If not go have the codes scanned.
Old Nov 19, 2012 | 06:10 AM
Hal 2000's Avatar
Got codes scanned: (thanks Scotitude)
P0456- Very Small Evap Leak- Have new oem gas cap coming today, will report back
P0657- Hvac Servos? Creaky, but works ok!
15504- Passenger Seat Airbag weight sensor? Pass air bag off light comes on at 5lbs, but works ok!
Durametric said engine, tranny, pcm, all areas all good.
Old Nov 28, 2012 | 05:22 AM
Hal 2000's Avatar
CEL Off! Looks like the new oem gas cap fixed it, as code P0456 could now be cleared. 100 mi. so far.
My old cap had only hairline gasket cracks, barely visible. A wet gasket appears to be normal on both.
Many thanks to 'Scotitude' and TKS Performance in Huntington Station for all the help- now my new shop.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Jul 29, 2019 11:13 AM
Mini George
Jan 18, 2016 09:16 PM
