Porsche Cayenne S 2006 0-100
Old Jan 9, 2013 | 06:04 AM
PORSCHE_SA's Avatar
PORSCHE_SA is infamous around these parts
Hi All.
My very first time on a forum. lol.
Recently bought a Cayenne S 2006. SPECS state that 0-100 can be done below 8 seconds.
I tried it and get it in somewhere between 10 and 11.5 seconds. Even visited the dealer to check whether I have a specific performance issue and tested a similar model with the same results.
what is your view of this ?
FYI : I am not at sea level, I have the vehicle in Drive and I do not change any of the standard safety settings i.e. traction control etc.
Old Jan 9, 2013 | 07:47 AM
Dennis C's Avatar
I believe the published 0-60 mph time is just over 6 seconds, so hitting 100 mph in 10 - 11 seconds seems reasonable.
Old Jan 9, 2013 | 07:54 AM
PORSCHE_SA's Avatar
Km/h
Hi Dennis
I was referring to Km/h
Regards
Old Jan 9, 2013 | 08:17 AM
ECS Tuning - Porsche's Avatar
First of all welcome to the forum and you must post some pictures of your newly acquired ride How much above sea level are you ?
Old Jan 11, 2013 | 02:41 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
You might try switching off "Porsche Save Me" (PSM - ie stability control.) It will make the shift points much more aggressive. If that doesn't work - using the Tiptronic manual mode may get you closer. The transmission control unit on the Cayenne is adaptive, it learns how you normally drive and adjusts shift points to optimize itself. If you drive non-aggressively the trans control learns this and goes for fuel mileage... which isn't good for performance.
Old Jan 11, 2013 | 09:37 PM
Enilder's Avatar
Enilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond repute
Put that in manual mode and PSM off. Try again and report back. Thanks.
Old Jan 19, 2013 | 07:29 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
you sure thats an S? that time is slower than the v6..lol
2lflat4
Nov 18, 2019 05:05 PM
albert@velosdesignwerks
Cayenne
Aug 28, 2015 06:36 PM
Cayenne 958
Aug 19, 2015 02:43 PM
