Engine no loacation for stencil purposes
I have googled and could find much information on this. Does anyone know where the engine number is located for stencil purposes?
I already found the VIN etched at the back of the truck where the spare wheel is located.
Its for my 09 Cayenne GTS
Cheers!
Cheers!
I don't know what stencil purposes are, but here's where to look for your engine number. Taken from a previous post elsewhere.
In the engine compartment, take a look at the lower righthand corner of your engine case near where the inner belt is lowest near the sheet metal. You should see the engine number stamped into the Aluminum case.
Look for the bolt head near where the belt starts to go down to the crank pulley. From the bolt head, look slightly forward and to the left about an inch to a vertical surface on the side of the case. You should see the engine number there. It may take an inspection mirror and flashlight to see the whole number.
Jul 29, 2019 11:13 AM
titannero
Audi
Aug 31, 2015 01:33 PM
