New Cell Mount on Handle in Cayenne from Ram Mounts
Old Dec 30, 2013 | 02:10 PM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
I recently found a very convenient mount and for 32 bucks off amazon and 3$ next day delivery, Im ranking this 3rd best mod for my 06 base.
Very ergonomic, like a 3rd hand in the rig, OK Google works great even with Stereo on with Nexus 5. Easy to make a few selections and keep eyes on the road.
If you want a window mount or Dash they sell those too.......Happy modding.
Name:	Ram Mount 1.jpg
ID:	316166   Click image for larger version
Name:	Ram Mount 2.jpg
ID:	316167   Click image for larger version
Name:	Ram Mount Actual 1.jpg
ID:	316168   Click image for larger version
Name:	Ram Mount Acutal 2.jpg
Old Jan 6, 2014 | 01:29 PM
mrbrianc's Avatar
mrbrianc is just really nicemrbrianc is just really nicemrbrianc is just really nicemrbrianc is just really nice
Thumbs up Nice
Thanks....just ordered one for my 09 CTTS.
Old Jan 6, 2014 | 08:45 PM
carreracup03's Avatar
carreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the rough
I just got the Ram version with the 2 zip ties that hold it. I also mounted on the passenger side. Wow what a great product!!! I am pretty impressed.
http://www.ebay.com/itm/121219184603...84.m1497.l2649
Old Jan 13, 2014 | 12:17 PM
cordsig79's Avatar
Good deal! Did the ziptie version come with a rubberized ziptie style to prevent indentation?
That is why I did the fatter tightening band with the rubberized inside strip.
Pictures would be great to add!
Old Jan 13, 2014 | 05:38 PM
Yes it comes with a sheet of rubber that goes under the zip ties. Really nice set up. I went with the zip ties, because it looked cleaner .. meaning looks like that handle clip might stick out. The zip ties, after they are trimmed, are completely flush.
There is a downside to the zip tie method ... I have to cut the ties to take off the mount. I am guessing you just unclip the one you have.
Old Jan 15, 2014 | 08:18 AM
cordsig79's Avatar
Just as a FYI for 10 bucks you can buy the RAM EZ-Strap Mount separately if you don't like the zip ties.......or just use more .02 cent zip ties.
To unzip mine, you just press the button to lift it off the EZ-Strap tracks and move the placement.
Old Jan 15, 2014 | 08:54 AM
Where do you see the base fir $10. I like the zip ties but would have both for another 10. Thx
Old Jan 15, 2014 | 09:01 AM
cordsig79's Avatar
Amazon-you already have the ball portion, just swap out the GARMIN one in it.
RAM EZ-Strap(TM) Mount with Short RAM-to-Garmin Double Ball Arm
$10.391
Old Jan 15, 2014 | 06:23 PM
$10.391
I do not have the same hardware as you do, and can not convert to the clip. I called RAM Mounts today to confirm. I have the handlebar kit, which does not have a ball. They use a different base without the ball for mine.
My thought process when I bought it, was that I thought the clip would stick out. I wanted it to be as non obtrusive as possible. This unit sits closer to the base than the clip model, which was better for my set up. What I gave up, was that I have to cut off the zip ties to remove the entire unit. I can easily unhook the bracket, leaving only a very small base. Also, I wanted to mount mine on the passenger side, and thought this one had a smaller base ... which I think it does, than the clip unit.
ID:	321737   Click image for larger version
ID:	321738   Click image for larger version
ID:	321739   Click image for larger version
Old Feb 5, 2014 | 01:35 PM
mrbrianc's Avatar
I mounted mine on the Drivers side, and removed the ez mount strap that it came with and added a velcro wire organizer strap in it's place. Looks much cleaner & easier to remove & replace & will not cause indentations.
Old Feb 5, 2014 | 02:09 PM
Where did you buy that. I would try that.
Old Feb 5, 2014 | 02:30 PM
mrbrianc's Avatar
Old Feb 5, 2014 | 07:39 PM
I bought some of those at Staples. They worked pretty well.
Old Feb 6, 2014 | 12:36 PM
mrbrianc's Avatar
Great, Glad you could find them.
The EZ strap was just too much in the way, with the extra length due to pull ring at the end.
Old Feb 10, 2014 | 08:13 AM
cordsig79's Avatar
Great mod guys, I am going to grab some. I adjusted mine higher up and got the pull tab interfering with my ability to work the manual/auto shifter
