08 cayenne turbo issues
Old Mar 7, 2014 | 07:59 AM
kevblah's Avatar
kevblah is infamous around these parts
hey guys, im hoping someone here might know what is wrong with my (wifes) 2008 cayenne turbo. a few days ago, my wife called me saying that the car wouldn't accelerate after siting at a stop light. she would press the accelerator pedal, but nothing would happen (her words).
I took her car for a ride that night and noticed something weird happening. at low rpms and low speeds (under 30mph), the car would be FULL BOOSTING. this is at like 3k rpm. this scared the crap out of me. car seemed to also lack power and was accelerating hesitantly.
I shut the car off and restarted it and it seemed to go away, but then happened again not too much later.
the issue with the car losing power / shutting off after being stopped for more than 20-30 seconds is reoccurring.
I was hoping someone would recognize these symptoms and could give some insight, before I tow it up to the Porsche dealer.
Old Mar 7, 2014 | 01:28 PM
aspenone's Avatar
aspenone is infamous around these partsaspenone is infamous around these parts
Diverter vavles maybe? Just a guess but you have to focus on what handles the boost the diverter valves might be stuck and need to be replaced.
Old Mar 8, 2014 | 06:18 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Just guessing, but it sounds like a major air leak or popped boost hose. This is not normal, so I doubt you are going to find a direct answer on these boards. Your best bet is to look over it carefully yourself or take it to someone else who will.
If you have a Durametric, you should probably have some codes stored as well.
Old Mar 20, 2014 | 08:00 AM
kevblah's Avatar
thanks for the help everyone
i brought it up to the dealer and they told me its a crankshaft sensor
only a $600 job, so i guess i get out unscathed this time
Old Mar 20, 2014 | 08:58 AM
Moderator
Thanks for the update. Glad to hear you got it resolved for not an arm and a leg. The crank and cam sensor are sensitive items and would definitely cause the issues you were experiencing. I think you would have most likely had a code stored in your DME as well.
Old Mar 26, 2014 | 08:14 PM
Vig03's Avatar
Vig03 is infamous around these parts
I wonder if others experienced issues with the Cam sensor? It seems early for a cam sensor to go out on an '08...am I wrong?
Old Mar 26, 2014 | 08:15 PM
kevblah's Avatar
well apparently the vehicle had a coolant leak at some point in its life. the coolant leak was repaired, but some of it had made its way into the sensor and over time fouled the sensor.
Old Mar 26, 2014 | 08:17 PM
Vig03's Avatar
Gotcha, that makes sense. Thanks
Old Mar 28, 2014 | 12:26 AM
996C2German's Avatar
996C2German is infamous around these parts
I had it too
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
