D1S Conversion Kit for 955 HID CT
Old Mar 23, 2014 | 06:13 PM
carrera4slakem's Avatar
carrera4slakem is infamous around these parts
Guys, has anyone wired up an aftermarket xenon D1S setup into the 955 Cayenne?
The Valeo ballast I heard are sensitive to aftermarket bulbs. Each ballast is like $300 a piece and you can get D1S HID kits for like $30 for two ballast, two bulbs and wire etc.
Anyone know how to tap into the wiring for the 12pin portion of the head light setup?
Old Mar 24, 2014 | 08:39 AM
Dennis C's Avatar
Didn't your CTT come from the factory with HID headlights? Why the change?
Old Mar 24, 2014 | 04:04 PM
I just ordered a $300 ballast. Swapped the working drivers side bulb and the passenger side still does not turn on. The bulb from the non working passenger side was swapped to the drivers side and the drivers side still works.
Then we tested the high beams and only the passenger side works and the drivers side doesn't work...
Then when the driver's side low beam didn't work we pressed down on the headlamp assembly and the hid light turned on....
Old Mar 25, 2014 | 06:13 PM
Dennis C's Avatar
Connection problems with the headlights are a common issue for the 955. There was a TSB issued for this problem because the headlight mounting bracket becomes loose and the connection is compromised. There are 10mm bolts on the front of the bracket that loosen up with time/use. Try tightening them and then seating the headlight assembly properly. Hopefully this will fix your issue.
97GtsMonster
Nov 17, 2015 12:38 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
ECS Tuning - VW
Aug 26, 2015 02:54 PM
TrackOne
Aug 20, 2015 12:56 PM
