Renntech Digital Lowering Module
Old Apr 14, 2014 | 07:43 AM
Mike@Renntech's Avatar
Mike@Renntech is infamous around these parts
The Volkswagen Audi Group (VAG) V3 Digital Lowering Module (DLM) is designed to work with VAG Air Suspensions. The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. These Air Suspensions are found in the following vehicles:
2004-2010 Porsche Cayenne (955/957)
  • Cayenne S
  • Cayenne GTS
  • Cayenne Turbo (S)
The V3 VAG DLM module requires no splicing or soldering.The RENNtech harness utilizes the factory pins as to allow a completely reversible installation.
All RENNtech DLMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently.The software also has three locations where the user can store pre-configured suspension setups for quick changes.
RENNtech VAG V3.5 DLM Module Specifications:
  • Current Consumption: 30mA (60mA while plugged in to PC/Tablet)
  • Adjustment increments: 1mm
  • Maximum Lowering: Limited only by vehicle
  • Adjustment Methods: PC or Android (Tablet)
  • Size: 53mm x 47mm x 17mm
  • Weight: 1.0oz
Please contact me with any questions or to place an order.
Optional Samsung Tablet
ID:	359536   Click image for larger version
adnanm3
Nov 22, 2023 02:43 AM
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
dgreen78
Feb 29, 2016 11:28 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
kensworth
Cayenne 955/957
Sep 9, 2015 05:45 AM
