cayenne Turbo S trans locked up in reverse, ever heard of this!?!?
Old May 17, 2014 | 07:26 PM
nitrorocket's Avatar
nitrorocket is infamous around these parts
My perfectly running 2006 Porsche Cayenne Turbo S was shifting 110% fine. I had pulled over to the side of the road put reverse and backed up about 100 feet, the second I let off the gas in reverse the truck came to a stop fairly quickly like I applied the brakes with a medium amount of effort. And there I sat stuck. The transmission completely locked up and will not move in reverse at all whatsoever not even if the truck is off, you can't even tow it or push it backwards, It will pull forward though but it will only drive forward about 1 foot before it locks up.
Has anybody ever heard of this???
Old May 18, 2014 | 12:38 AM
Jus4me's Avatar
Jus4me is infamous around these parts
Sounds like your transmission is shot. Had that happen to me in my old Lexus when its transmission failed.
Old May 18, 2014 | 07:29 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
In a 4-wheel Drive vehicle it could be a couple of things. Obviously you need it flat bedded to your mechanic/dealer for evaluation. They'll let you know whether it's a transfer case, transmission or something out of alignment. Just don't force it so something additional happens.
Old May 18, 2014 | 11:58 AM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
A transfer case motor that is misbehaving can cause such symptoms.
Old May 26, 2014 | 08:21 AM
aspenone's Avatar
aspenone is infamous around these partsaspenone is infamous around these parts
great advice with this and to add I had a similar thing happen to me in my pickup truck rear wheels locked up on me and spun me sideways, after coming to a stop I have able to drive off I chewed up a few teeth in my rear diff. Hopefully its not your transmission
Old May 30, 2014 | 08:10 AM
So... What was the issue?
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
