Servicing?
Old Jul 22, 2014 | 03:27 PM
Drk Knight's Avatar
Drk Knight is a jewel in the roughDrk Knight is a jewel in the roughDrk Knight is a jewel in the rough
Servicing?
So I just hit 70,600 miles and my car had a message pop up "Service in 1900 miles"
What should I be servicing?
Old Jul 22, 2014 | 03:45 PM
XLR82XS's Avatar
Check the maintenance guide in the owners manual.
Old Jul 22, 2014 | 06:05 PM
CALMOTION's Avatar
CALMOTION is just really niceCALMOTION is just really niceCALMOTION is just really niceCALMOTION is just really nice
I assume that's oil. I'm about 100 miles from same pop up.
Old Jul 22, 2014 | 06:51 PM
Drk Knight's Avatar
Yea I had assumed oil, but wasn't sure if anything else. My dad has the book so I can't check at the moment so I thought I'd ask here.
Old Jul 23, 2014 | 03:18 AM
gh0stman's Avatar
gh0stman is infamous around these parts
I beileve this is what constitutes your next service.
- Oil Filter, o-ring, and crush washer
- Wiper Blade Set - Front & Rear Sets
- Summer Windshield Wiper Fluid
- Pollen Filter
- Engine Air Filter Set (Left & Right)
- Spark Plug Set (8 plugs)
Recommended inspections for this mileage:
- Diagnostic system - read out any faults in memory (Porsche Dealer)
- Check windshield & headlight washer system & nozzles.
- Check horn function
- Inspect tire condition and air pressure, including spare tire
- Check battery condition and vent hoses
- Check function of electrical equipment, including warning and turn signal lights
- Radiators and air intakes: Visual inspection for exterior debris and blockage
- Check the door, lid locks, and hood latches for proper function
- Check drive belt
- Clean reversing camera lens
- Check vehicle lighting and headlight functionality
- All headlights: check adjustment
- Check firewall body drains and sunroof drains for debris
- Inspect all under-body panels - ensure all are secure and tight
- Inspect coolant level and antifreeze
- Visual inspection of pads & rotors for signs of wear
- Inspect brake hoses and lines
- Inspect all drive shaft boots for leaks, wear, or damage
- Drive shaft/Cardan Shaft: Visual inspection of the rubber
- Coolant and hoses: Check level and antifreeze, check conditions of hoses
- Power Steering - Check Fluid Level
Additional checks for this mileage:
- Trailer Hitch: Check operation
- Lubricate door, door latches, and fastening bolts
- Steering Gear & Tie Rod Ends: inspect boots for damage, check for play on tie rods
- Exhaust System: Visual inspection for leaks and signs of damage, check mounts
- Check for leaks, including engine oil, fuel, transmission, and coolant
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
