S.S. front skid plate
Old Oct 15, 2005 | 07:56 PM
jgraham's Avatar
jgraham is infamous around these parts
Just received a stainless steel front skid plate for my 05 cayenne turbo. Anyone did this before can give me some pointers on how to remove stock piece or does it install over existing. Have removed all fastners I can see, even in wheelwell, stock part seems to all one piece from wheelwell to whellwell. Any help would be appreciated.
Old Oct 16, 2005 | 07:16 AM
Shawn C's Avatar
Shawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond repute
Search here.
http://www.renntech.org/forums/lofiv...x.php/f31.html
Member "Kevin M" did it himself and photoed the entire project.
Old Oct 16, 2005 | 12:57 PM
jgraham's Avatar
Thanks for the link, I saved it, did not find it on my first look, will check again later.
Thanks, John.
Old Oct 16, 2005 | 09:47 PM
mudman2's Avatar
mudman2 is infamous around these parts
Depending on your skill level it will take about 2 hrs start to finish,mostly trying not to damage the paint work. You can take the front off by yourself but you will need a second pair of hands to put it back on, (my wife helped me)
It fits over the existing plastic cover, you need to make sure you have the Porsche small parts kit along with the plate itself.
Various torx / crosshead drivers and a drill are needed.
I used moving pads on the ground under the front of the car to save any bad bumps as it comes off.
Use the opportunity to 1) change fog light bulbs to white ones, 2) replace the hood badge, 3) change side markers to clear.
Enemy
Nov 10, 2015 08:01 AM
007AMV8
Oct 19, 2015 09:55 PM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
