955 Fuel preasure
Old Feb 9, 2015 | 02:13 PM
BG305's Avatar
BG305 is infamous around these parts
955 Fuel preasure
So I checked the PSI on each pump by having the fuse pulled on each of the pumps. I noticed that with both fuses in my fuel preasure would bounce from 50-57psi. I then check them individually and it only does this with my primary pump working. When I use the secondary by its self the preasure stays at a steady 57psi. Is my primary pump on its way out?
Old Feb 10, 2015 | 03:32 AM
gh0stman's Avatar
gh0stman is infamous around these parts
Did you get pressure with the primary pump?
Old Feb 10, 2015 | 03:05 PM
BG305's Avatar
Yes, it just wasn't solid. It would bounce from 50-57psi where as the secondary pinned it at 57psi.
Old Feb 10, 2015 | 03:18 PM
TT VIPER's Avatar
TT VIPER is infamous around these parts
I'd recommend hooking the car to the computer and checking all the systems and faults. Fuel pumps do not fail too often on CTT's and replacement of fuel pumps are labor intensive.
Old Feb 11, 2015 | 07:14 AM
BG305's Avatar
I have a durametric and checked for faults. The reason I checked the fuel pumps is the car has a stutter accompanied with a poping in the exhaust. It's happening from 3-3,800rpm when it starts boosting.
mxracer
Dec 28, 2015 08:17 AM
COBB Tuning
Nov 3, 2015 08:39 AM
carlosC4S
Cayenne 958
Sep 26, 2015 10:13 AM
