Is it safe to jack up the CTT with suspension warning activated?
Old Apr 2, 2015 | 09:18 AM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
I can't turn off the suspension control by holding the selector forward for 10 seconds. No response. So, if I jack it up, will it cause problems? How do I make sure it goes safely? Jack up from wheel/trailer arm? I need to get new tires on.
My Cayenne Turbo still goes all the way up and down with the lever control, but nothing happens when I try to turn it off. It says accumulating pressure or such. It takes too long to charge up after start-up, so the re-set does nothing. Any idea's? I was lowering the pig with durametric and the No.1 wheel will not communicate with the software, so now it stays on the warning. If I can get No. 1 to work, I'll just reset to factory.
Old Apr 2, 2015 | 10:00 AM
BOOSTTT's Avatar
OK!!!! after 4 days of trying to get my durametric and suspension to talk, I finally got all 4 wheels adjusted and saved. Now I can turn of the control to jack up my pig. I do not recommend using the durametric lowering control. PITA, and you may not be able to clear the faults. Lower with a module or links to be safe. Yea! Glad that issue is solved.
Old Apr 3, 2015 | 10:29 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
glad to hear you got it resolved. With the durametric, if you cant save and finish the procedure with all 4 corners, it causes the air suspension work shop message until it can finish the procedure. Im guessing since it didn't let you save all of the values you were unable to finish, which caused the error.. Glad you finally got it figured out. These trucks can be annoying at times...
Old Apr 4, 2015 | 10:11 AM
BOOSTTT's Avatar
Your exactly correct. I'm not messing with that again. Just happy it's functioning now.
henryr
Sep 24, 2015 08:22 PM
Michael_s
Sep 11, 2015 08:03 PM
PelicanParts.com
Aug 28, 2015 12:53 PM
PelicanParts.com
spreeon
Aug 27, 2015 08:14 PM
