Cel and 2 codes need help
Old Apr 3, 2015 | 05:11 PM
rlhornbeck's Avatar
rlhornbeck is infamous around these parts
The CEL came on today so I pulled out the Durametric and found 2 codes
P2677: O2 Sensor Pumping Current Trim Circuit Bank 2 Sensor 1 - No Signal/communication, test conditions are not-completes, fault is active and causing a DTC light
P0150: O2 Sensor Circuit Bank 2 Sensor 1 - Implausible signal, test conditions are not-complete, fault is currently active and causing a DTC light
Where should i start looking for a problem or is it as simple as an O2 sensor? if so how do i test the sensor to confirm that is the problem.
Old Apr 4, 2015 | 10:16 AM
Rvca3112's Avatar
Rvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant future
Seems to be a simple 02 swap. Also let us know what kind of truck we're looking into for you....
Old Apr 4, 2015 | 10:35 AM
rlhornbeck's Avatar
We are working on a 2005 Turbo.
Looking into the replacement unfortunately it does not look simple.
Any insight on DIYing this?
Old Apr 4, 2015 | 11:42 AM
Rvca3112's Avatar
This may shed some light for you brother. I see a few drinks in your future with this job haha
http://www.renntech.org/forums/topic...oxygen-sensor/
Old Apr 4, 2015 | 01:23 PM
rlhornbeck's Avatar
Rvca3112,
Thanks for the help so far. I think you are correct time for a drink and then go climb under the car for an inspection.
Old Apr 9, 2015 | 11:57 AM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
Difficult job, but sounds like O2 sensors. You can clean the plugs on top and see if that helps first. Good luck.
BLKMGK
May 31, 2016 04:32 AM
intouch1
Sep 20, 2015 06:14 AM
Yogi911
Sep 9, 2015 08:20 PM
