Front differential - 955 Turbo 2003
Old Oct 4, 2015 | 08:05 AM
Yotam Refael's Avatar
Yotam Refael is infamous around these parts
Hi,
its look like i need to replace my front differential on my 2003 Cayenne Turbo...
Does anyone know if the vw touareg front differential fits to my porsche cayenne?
Its look the same and hvae the same Part No. but i dont know if its fits...
Thank you
Old Oct 8, 2015 | 08:48 AM
DLF's Avatar
DLF
DLF is infamous around these parts
The Touareg and Cayenne do use similar front diffs, however the diff ratios for the models vary. Turbo, S and base Cayennes all have different front diff ratios. You will have to find the Touareg with a diff ratio matching your Turbo. I'm not sure that the part number on the diff casing reflects the diff ratio inside, or maybe you are lucky and have picked the right one !
Old Oct 22, 2015 | 07:07 PM
Brainz's Avatar
Brainz is infamous around these partsBrainz is infamous around these parts
Note that if the bearings are growling, there is an extensive post on the Touareg forums detailing the needed replacement bearings and instructions to fix. Seemed like a cheaper option for a good indy mechanic or advanced shade tree diyer.
stevenrmusic
Bentley
17
Nov 12, 2015 05:53 PM
albert@velosdesignwerks
Cayenne
Aug 28, 2015 06:36 PM
carrera4slakem
Aug 24, 2015 08:14 AM
Cayenne 958
Aug 19, 2015 02:43 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
