Those with the aftermarket reverse camera from ebay.
Old Jan 19, 2016 | 03:09 PM
kino1161's Avatar
kino1161 is infamous around these parts
Right before you plug the RCA cable to the PCM via the FAKRA cable in the back of the PCM, what did you do with the remaining red wire coming from the RCA end?
Old Feb 15, 2017 | 03:55 PM
sureshot's Avatar
sureshot is infamous around these parts
Red wire
This wire needs to be spliced into a red wire in the main wiring loom and gives the camera power to work. At the other end where the camera is, you will need to splice the camera's red wire to the red wire on the video cable. The black cable on the camera (if there is one) should go to a ground.
blackonblack996
Jan 17, 2016 07:53 PM
MadWhip
Jan 15, 2016 09:40 PM
ioskopower
Cayenne 955/957
Jan 15, 2016 02:04 PM
MkC2S
Jan 14, 2016 10:56 PM
