Serpentine belt
Old Dec 30, 2016 | 12:18 PM
markar's Avatar
markar is a name known to allmarkar is a name known to allmarkar is a name known to allmarkar is a name known to allmarkar is a name known to allmarkar is a name known to all
Serpentine belt
Hi Guys, how much for serpentine belt replacment cost at the dealer?
Old Dec 31, 2016 | 01:54 PM
twilight's Avatar
twilight is infamous around these parts
My local shop wanted $475. Bought the part at Carquest and it took me 30 minutes - great DIY at Pelican Parts. The belt routing diagram is on the front of the engine. You need a 30mm Socket or open end wrench to turn the tensioner about 30-40 degrees to loosen the belt for removal. Easy Peasey Lemon Squeezy.
A good thing to look at - unlike most cars - it does not exactly stare out at you when you open the hood - mine was in dire condition.
Old Jan 1, 2017 | 09:08 AM
markar's Avatar
Thankyo for info. I don't have time or talent to do this my self, I will go talk to local shop.
Old Jan 1, 2017 | 01:23 PM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
You must carefully inspect the plastic center pulley and determine it will last another 90k/miles or so. If it even looks dry in spots - replace it.
Old Jan 1, 2017 | 10:08 PM
markar's Avatar
Thank's ,My cayenne s have 131k/miles i will replace the puly and check the water pump .
