“Humming/whining” sound from rear wheel well area when idling. (04 Cayenne S)
Old Feb 19, 2017 | 11:41 AM
grphcdsgnr76's Avatar
grphcdsgnr76 is infamous around these parts
I have a “humming” (for lack of a better term) sound coming from the rear wheel well area when at idle (I assume its also happening when traveling and I just can’t hear it over road/wind noise.) It seems to be a bit more prevalent on the driver's side but isnt clearly only coming from there. I’ve heard of similar sounds happening on other vehicles with air suspensions and it being related to faulty sensors in those cases. Any one here have any experience with an issue like this and any guidance as to possible causes and solutions?
Side note here, I do get random air suspension faults on the dash, however, there is no rhyme or reason to when, or if, they occur. Further, even when they do pop up the air suspension still functions even when the fault is “active” (further leading me to think this might be some kind of sensor issue as opposed to an actual system issue.)
Attached vid is of the noise, its a bit tough to hear over the idle and wind, but its there.
The vehicle is a 2004 Cayenne S.
Thanks.
File Type: mov
Old Feb 23, 2017 | 02:13 AM
gh0stman's Avatar
gh0stman is infamous around these parts
Are you talking about the sound that (to me) sounds like a electrical power station?
Old Feb 24, 2017 | 11:03 AM
Yup, that's the one. Its been suggested to me that its a normal operating noise from the fuel pump—which would be great because, hey, one less thing to fix— but I'm open to other opinions.
Old May 27, 2017 | 02:42 PM
Bear Glass's Avatar
Bear Glass is infamous around these parts
Was the humming a normal operation?
