Cayenne S Engine Codes
Old Sep 5, 2018 | 08:37 AM
wtsnt's Avatar
wtsnt is infamous around these parts
I recently purchased a 2008 Cayenne S. Yesterday the car took a while to start and had a very rough idle at approx. 400 rpm. The Check Engine light was on and when I read the codes I got:
Stored Codes:
P1372 Unknown Diagnostic Trouble Code
Pending Codes:
P1353 Unknown Diagnostic Trouble Code
P1351 Unknown Diagnostic Trouble Code
P0174 System Too Lean Bank 2
The P0174 code is probably related to a bad O2 sensor. Does anyone know what the other "Unknown Diagnostic Trouble Code" are?
Thanks,
Terry Watson
Old Sep 6, 2018 | 11:56 AM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Terry,
Spending about 3 minutes with Google turned up the answer for your first code..
http://forums.pelicanparts.com/porsc...ode-p1372.html
I'll let you do the work for the rest of them.. try "Porsche Cayenne P####" (whatever the P-code is..) All codes > 0999 are manufacturer specific. It's where a tool made to be used with a Porsche becomes valuable and you don't waste time dicking around on Google or some forum. There are several tools available, one for under $200 (iCarScan) - and I'd suggest if you're going to be doing DIY sort of stuff to your Cayenne - it's well worth the investment.
Hogapalooza
Sep 23, 2010 11:29 PM
rrdralli
Sep 2, 2010 03:25 PM
Jose Aponte
Aug 3, 2010 05:17 PM
thebk
Oct 2, 2006 02:41 PM
Cody_1
Feb 17, 2005 11:58 PM
