Air suspension help
Old Mar 26, 2024 | 09:09 PM
Flight951's Avatar
Flight951 is infamous around these parts
Air suspension help
having trouble figuring out what the problem is with my Air suspension.
In an effort to fix my issue. right now the rear rises but the front is fully down. I changed the Valve block with no improvement. But when I disconnected the rear hose from the valve block, the rear came down. Is that a sure sign the rear valves are working??
And conversely if the front valves were bad, would it not air up??
I keep getting the error P1400 "below lower limit Exceeded, Control position not adjustable"
The pump stops running when that error comes up, if I clear it it will start again (but front doesn't move at alll)
the height sensor readings seem to be in the ball park.
ciaka
Apr 30, 2026 11:39 PM
PrestigeLdn
Bentley
24
Oct 13, 2021 03:20 AM
957Turbo
Bentley
Jan 22, 2021 02:50 PM
gtjay
Bentley
27
Sep 10, 2019 07:33 AM
bonemechanic
Cayenne 955/957
Sep 11, 2014 10:30 AM
