22's and vibration at speed
Old Jul 25, 2006 | 09:53 PM
Cognac's Avatar
Cognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant future
I thought that was a common problem for Cayenne.
I have 18'(flower wheel ) now and had same issue.
Between 60-70mph, my steering vibrated little.
Took that down to tire shop and re-balanced...problem fixed.
I would change tires to Michelins or Nitto or Advan...specially with Gemballa.
Or drive below 60 or go beyond 70 to eliminate problems.
Or have you checked your wheel? no damage internally? hope you checked when you bought it.
kdubb's Avatar
kdubb is infamous around these parts
Originally Posted by evsmotors
You should go get the wheel/tires balanced at a reputable place.
as I said, I had the wheels/tires balanced at the Porsche dealer and they use a Hunter Road Force Machine... probably the best machine on the market today
Old Jul 25, 2006 | 10:06 PM
CayenneTurbo77's Avatar
CayenneTurbo77 has a spectacular aura aboutCayenneTurbo77 has a spectacular aura about
KDubb---Its the Perelli's.....I had the same problem with my 22's....changed the tires to NITTO NT55 's and the shaking is gone and the car handles far better than with the Perelli's ....
Old Jul 26, 2006 | 12:20 AM
GoldenPEPPA's Avatar
GoldenPEPPA is infamous around these parts
I've heard about lots of shady vibes on 295/30-22 Pirelli's.... that wouldn't happen to be your size, would it?
Old Jul 26, 2006 | 01:22 AM
wan888's Avatar
wan888 has much to be proud ofwan888 has much to be proud ofwan888 has much to be proud ofwan888 has much to be proud ofwan888 has much to be proud ofwan888 has much to be proud ofwan888 has much to be proud ofwan888 has much to be proud ofwan888 has much to be proud ofwan888 has much to be proud of
i don't think it's the tires either ... unless you track your car alot and created a flat spot which is highly unlike for a car with ABS.
Old Jul 26, 2006 | 05:33 AM
SHAIKH's Avatar
SHAIKH has a spectacular aura aboutSHAIKH has a spectacular aura about
Its The Tires
i am 150% sure thats its the tires. i got the new BMW 750li and it was wobbling like crazy at around those speeds and i took it to the dealer and did the alignment, balacing..the works. a couple of times actually. It had pirellis on them and i told them that i had asked to michellins. The pirelli people also came down and took the tires for inspection and told me that one of the tires had a flat spot and changed them for me.
but the problem persisted and then when i asked for michelins to be fitted....it was like there was no problem at all. even the service manager told me that pirellis are not good tires. change your tires i think everything will be ok then
Old Jul 26, 2006 | 07:04 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Originally Posted by kdubb
well... is there any certian specs/tips I can tell the dealer when they balance the wheels/tires ?
If you go to renntech.org and make a $20 donation for lifetime member, you will see a TSB bulletin for the Cayenne that addresses the complicated wheel balancing procedure to eliminate vibration using the Hunter road force balancing machine. Best of luck...
Old Jul 26, 2006 | 09:58 AM
iaAaron's Avatar
Awaiting Email Confirmation
iaAaron is infamous around these parts
I would check the alignment and then check to see if the tires have any flat spots. Best of luck.
Aaron
Old Jul 27, 2006 | 04:27 PM
adybuncio's Avatar
You have that much metal and that less rubber, expect vibrations. My client has an S550 on 22s, and it wobbles. but not that much that its a hastle to deal with
Old Jul 28, 2006 | 11:56 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
Hunter Machine
Just cause they use that machine doesn't necessarily mean they did it properly. I would have them re ROAD FORCE balnce the wheels where they actually have to turn the tire on the wheel an this should fix ur issue. try it out!
-SM
Old Jul 28, 2006 | 12:36 PM
kdubb's Avatar
well, Pirelli is crediting me for 2 tires and I ordered a set of 4 Nitto NT555's.... we will see what happens
Old Jul 28, 2006 | 08:02 PM
:thumbsup:
Will probably clear it up. Although if you search the board there are threads about 2003-2004 Cayenne with chronic steering shake with all size tires.
adnanm3
Nov 22, 2023 02:43 AM
Suds26
Sep 2, 2015 01:33 PM
MC36
Southeast
Sep 1, 2015 06:39 PM
