Help me my CTT is all f*ed up
Old Jan 17, 2007 | 08:28 PM
mono2100's Avatar
mono2100 is infamous around these parts
Last week my car began giving me a psm error. So I took the car in and the tech notified me that it was ok. Yesterday as im going about 60 on the freeway the psm error pops up...my car decides to shut off, I have no steering control...I start pumping the brakes and luckily I was able to stop the car put it in park and get it restarted. I drive off the freeway and as I pull up to the freeway off ramp the front of my car collapses... my front air suspension gives up and I get an warning air suspension failiure.
WTF should I do?
Old Jan 17, 2007 | 08:32 PM
turbo187's Avatar
turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !
Originally Posted by mono2100
WTF should I do?
take it to the dealer maybe
Old Jan 17, 2007 | 08:36 PM
kraeburn's Avatar
kraeburn is infamous around these partskraeburn is infamous around these parts
Yeah, that would be a prudent decision at this juncture.
Old Jan 17, 2007 | 08:38 PM
LIL RAJA's Avatar
LIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant future
Old Jan 17, 2007 | 08:40 PM
mono2100's Avatar
obviously...but any indications on what this may be caused by? my car is moded, ECU, bypass etc...no lowering module, and I dont want the dealer to make any excuses...considering their tech looked at the car and informed there were no issues with it.
Old Jan 17, 2007 | 08:42 PM
BobbySpeed's Avatar
BobbySpeed is infamous around these partsBobbySpeed is infamous around these parts
Take it back to the dealer and take them for a ride. It could be that your computer needs to be reset or replaced since it is not storing codes, is lowering the ride height without being told to, and thinks there is a PSM error.
The other thing is that if your PSM really could be malfunctioning- it can trigger a ride height change and signal the computer to shut down.
The reason I bring up the computer first is because your computer didn't produce the code when they scanned it for codes.
Honestly, we cannot say for sure since we are not connected to your car.
Or, it could also be your PASM that is failing and triggering your PSM warnings- but then why didn't your computer report the proper code identifing that issue.
Ultimately, if your dealer treated you poorly when he couldn't find the error you should go to a different one if you can.
If I were you, I would have it flatbedded in and not take a chance driving it again until the problem is solved.
Good luck!
Old Jan 17, 2007 | 08:59 PM
Vladcanada's Avatar
Vladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of light
Sell the car and get ML63!
Old Jan 17, 2007 | 09:08 PM
BobbySpeed's Avatar
Wow, that was helpful.
Old Jan 17, 2007 | 09:49 PM
Cognac's Avatar
Cognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant future
did you put chevron again?
sry to hear your trouble.
Old Jan 17, 2007 | 10:01 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
ML63 is crap, if the Cayenne was not made maybe..
but i'd rather get the G55
Old Jan 17, 2007 | 10:02 PM
alex911s's Avatar
WTF should I do?
that's a known issue.. might be the compressor...
Old Jan 17, 2007 | 10:04 PM
turbo187's Avatar
sorry i couldn't be more help!
Old Jan 17, 2007 | 10:17 PM
Cognac's Avatar
Originally Posted by alex911s
ML63 is crap,...but i'd rather get the G55
+1 here.
wish i can help....
Old Jan 17, 2007 | 10:18 PM
BobbySpeed's Avatar
Or, it could also bea compressor for your PASM that is failing and triggering your PSM warnings- but then why didn't your computer report the proper code identifing that issue???
Alex heard of this, so you should Google cayenne compressor failure.
Old Jan 17, 2007 | 10:34 PM
alex911s's Avatar
