Safe to replace 5W bulbs for 10W bulbs (license plate lights)?
Thinking of getting these: http://www.eautoworks.com/html/ORD-1-1-1-2067.cfm for the rear license plate lights.
However, I noticed that the wattage on these bulbs are 10W while the OEM stock one is 5W. Is this safe? Will the connector burn/melt because of the higher wattage? Please advice. Thank you.
Originally Posted by MexicoBlue
Maybe, but wouldn't you really rather replace your 5W license plate lights with 1W bulbs? Or even 100mw bulbs?
Definitely darker not brighter, dont want to help the traffic cops catch you!
Sorry thsiao I found a website that notes that the Ampage will increase by 2 times if you change from 5w to 10w which takes you from .8amps to 1.6 amps.
I dont know however if that will harm the wires. Over to the experts for that.
I had a look around to see what you could do and came up with the same supplier you got your LED's from which I would have thought would work?
Good luck!
Good luck!
Originally Posted by djantlive
just get a 5w bulb that is hyper blue if that's what u want. local auto supply shop should have them. don't need brighter stuff and risk melting your harness.
Anyone know where I could find hyper white bulbs in 5W?
Originally Posted by SpeedDemon
no faults i assume?
