Cayenne 958 Vendor Classifieds Vendors post your classifieds here
:: ECS Tuning :: Chemical Guys Automotive Detailing Products | Now Available !!
Old Apr 18, 2013 | 03:09 PM
ECS Tuning - Porsche's Avatar
Most of us have to admit to sleeping through a chemistry class--or two--after a rough night. The good news is the Chemical Guys didn't.
Now they've put the power of Raw Science to work in a complete professional detailing car care line that combines surface-safe cleaners with lasting protectants and sealers. Stop squirting dish detergent into a bucket. Remove the toughest dirt, even from alloy wheels, and restore your car's exterior and interior finishes to a rich, lasting luster.
Click Here for more information and to purchase
Old Apr 22, 2013 | 01:21 PM
Make sure your ride looks as good as you do with this master interior detail kit.
Kit Contents
  • Fabric-Guard Interior Protectant - 16oz
  • UFO Applicator x2
  • GreenCLEAN All Surface Cleaner Concentrate - 16oz
  • Glassworkz Optical Clarity Cleaner - 16oz
  • Ultra-Fine Microfiber Towel x12
  • Clear PVC Spray Bottle - 16oz
  • Ultimate Vent & Dash Brush Kit - 3 piece set
  • Lightning Fast Carpet & Upholstery Cleaner - 16oz
  • Pure Leather Conditioner - 16oz
  • Leather Cleaner - 16oz
We've provided you with everything you could need short of a vacuum and a couple hours to get the job done.
Old Apr 24, 2013 | 02:39 PM
You wash yourself from head to toe right? Why not do the same for your ride? This Master Detailing Kit includes everything you need to do the job.
Kit Contents:
  • Luber Clay Bar Lubricant - 16oz
  • Gerbil Wheel Brush
  • Detailing Bucket - 3.5 Gallon
  • Durafoam Tire Dressing Applicator
  • Citrus Wash & Gloss Car Wash - 16oz
  • 3 UFO Applicators - 4" x 1.25"
  • Fine Grade Poly Clay Bar - 100 Gram
  • V.R.P. Dressing - 16oz
  • Glassworkz Glass Cleaner - 16oz
  • Extreme Top Coat Liquid Wax - 16oz
  • 3 Elite Microfiber Towel
  • 12 Ultra-Fine Microfiber Towel
  • Deep Reflection XP Final Polish - 16oz
  • Contoured Tire Brush
  • Premium Blue Wheel Cleaner - 16oz
  • Big Monster Microfiber Towel
  • Mega Foam Blaster
  • Scratch & Swirl Remover - 16oz
  • Premium Extra Thick Wash Mitt
Old Apr 26, 2013 | 02:16 PM
When it comes to the show season it pays off to have a quick detail kit on hand. With this kit you will always be prepared to tackle a quick shine, so there's no excuses.
Old Apr 30, 2013 | 02:42 PM
You wouldn't go out for a night on the town wearing some busted up old shoes would you? Then don't treat your ride the same way.
ECS created this kit so you get the right tools and chemicals from the right guys, the Chemical Guys.
Kit Contents
  • Elite Microfiber
  • Premium Blue - 16oz
Old May 3, 2013 | 01:54 PM
This kit is designed to give your ride's exterior a complete makeover.Included are all of the liquid products you will need for complete paint and scratch correction.
To get the most out of this kit, it should be paired with an orbital polisher and appropriate applicators for cutting, polishing and finishing, which can be found under our detailing tools section.But for this kit to truly shine the brightest, try it out on dark paints or paints with metallic or flake.
This comprehensive kit includes:
  • V34 Optical Select Hybrid Compound - 16oz
    This compound works best when paired with a white polishing pad
  • V36 Optical Grade Cutting Polish - 16oz
    This compound works best when paired with a blue polishing/finishing pad
  • V38 Optical Select Hybrid Final Polish - 16oz
    This compound works best when paired with a black finishing pad
  • V7 Optical Select High Gloss Spray Sealant - 16oz
  • Petes 53 Black Pearl Paste Wax Jar - 8oz
  • Black Light Radiant Finish - 16o
Old May 10, 2013 | 12:27 PM
The color black has the ability to shine more than any other color paintwork. This kit was designed to take that shine to its highest level. Simple, yet effective:
The Kit Includes:
  • BLACK Luminous Glow Infusion Wax for Black Cars & Finishes 8oz
  • BLACK LIGHT Hybrid Radiant Finish Gloss Enhancer + Sealant 16oz
  • BLACK Monster Edgeless Microfiber Super Plush Towels
  • BLACK Ultra-fine WAPS Black Foam Applicator
Using advanced super polymers that repel airborne pollutants, water, and ultraviolet radiation, BLACK products from Chemical Guys are sure to impress any enthusiast.
Old May 16, 2013 | 01:54 PM
Have you ever struggled with getting the dirt or dust out from around emblems, your shifter boot or your dash vents?
Struggle no more, this simple 3 piece kit includes the right parts to get the job done.
  • Vent Detailer - Easily cleans vents and hard to reach surface areas
  • Dash Detailer - Perfect for the seams between panels on your dashboard and on your doors
  • Crevice Detailer - Great for stuck in grime and hardened wax in the worst places like around your shifter boot or emblems.
Old May 24, 2013 | 10:38 AM
The Foam Blaster houses a sturdy 32oz reservoir housing for diluting any soap or cleaner of your choice. Reservoir is also graded to help with diluting your soaps and cleaner. Simply load your favorite soap or cleaner into the 32oz canister dilute as desired. Then when connected with a hose you will unleash mounds upon mounds of cleaning foam to your vehicle. When you are done foaming the vehicle, simply quick release the Foam Blaster from the foam spray nozzle and rinse the vehicle clean with water.
Old Jun 5, 2013 | 01:32 PM
Do you want the very best finish for your ride? This dual action polisher will improve the texture and luster of your paint with virtually no risk.
Since orbital polishers oscillate instead of rotate, they will not leave the dreaded buffer swirls or holograms into your finish as long as you use the appropriate chemicals, buffing pads and bonnets.
Old Jun 12, 2013 | 01:53 PM
Even if your car is 5+ years old, you'll swear it feels new after using the Chemical Guys leather cleaner and conditioner. This two step system first removes any grunge that may be sticking to the leather with the cleaner and then restores the leather fibers with moisture through the conditioner.
Kit Contents Include:
  • UFO Applicator
Old Jun 21, 2013 | 12:59 PM
Spill your coffee on the way to work? Take your furry companion on a long ride recently? This Basic Cloth Interior Detail kit provides you with everything you need to prevent anyone from knowing it ever happened.
If your floors have seen better days, you're going to love the Lightning Fast carpet and upholstery cleaner, safe for cloth seats too!
Just because your ride is dirty, doesn't mean your hands have to be, so we included 12 microfiber towels for wiping off products.
  • Lightning Fast - Carpet & Upholstery Cleaner - 16oz
Old Jun 28, 2013 | 01:08 PM
We've provided you with the essentials for a complete wash and wax since we know you'd rather be enjoying your car then spending time thinking about the stuff you need to keep it clean.
Kit Content
s:
  • UFO Applicator
  • 4' x 6" Microfiber Applicator
  • Elite Microfiber Towel
  • Maxi Suds II Wash - 16oz
  • M-Seal Factory Sealant / Wax - 16oz
Old Jul 12, 2013 | 02:18 PM
Stop looking at those stains from a dropped coffee or burger, get some lightning fast carpet & upholstery cleaner and get on with it. Lightning Fast contains powerful cleaning agents to remove stubborn stains from carpet, upholstery, fabric and more. The unique emulsion lifts away contaminates while eliminating the need for vigorous scrubbing.
Lightning Fast can be sprayed on and wiped off, it can be brushed in and vacuumed out or it can even be put into leading extractor machines for superior result.
Old Jul 19, 2013 | 02:07 PM
Does your paint feel ruff to the touch? Then a clay bar is what your looking for. A clay bar will easily and safely remove stubborn contaminates that will not be removed during the washing process.
Removes surface damaging contaminants such as tar, tree sap, bird droppings, bug smear, embedded road grime, paint over spray, and airplane fallout. Which can leave surfaces rough and gritty. We've provided you with the essentials to properly clay bar your vehicle since we know you'd rather be enjoying your car then spending time thinking about the stuff you need to keep it clean.
Kit Contents:
  • UFO Applicators - 4" x 1.25"
