2011 PASM low Setting
Old Apr 17, 2011 | 05:09 PM
galion's Avatar
galion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud of
I read somewhere that driving in the low setting may result in uneven tire wear as the vehicle is aligned at normal height, is this true?
In what setting do you drive yours?
Tks.
Old Apr 17, 2011 | 06:10 PM
canberk's Avatar
canberk is infamous around these parts
that's complete bs. i drive in the lowest setting all the time (for 4 years) and no such thing happened
Old Apr 17, 2011 | 08:37 PM
galion's Avatar
Thats what I thought, but from a technical point of view, if camber varies, then the tires should wear unevenly when using the lower setting in an all time basis, unless canber is corrected with the PASM feature, which I doubt.
Old Apr 17, 2011 | 09:45 PM
Qualeek's Avatar
Qualeek has a spectacular aura aboutQualeek has a spectacular aura aboutQualeek has a spectacular aura about
PASM does not vary the camber, caster or toe angles. agree with canberk, total BS
Old Apr 18, 2011 | 01:10 AM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
adjusting height would change the geometry, so the values have to change..
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
JMon
Aug 21, 2015 08:20 AM
ppwchiang
Aug 20, 2015 10:28 AM
