Config Question : Base Cayenne V6 & Stick Shift = No PSE?
Old Feb 12, 2012 | 10:35 AM
ikegram's Avatar
ikegram is infamous around these parts
Question Config Question : Base Cayenne V6 & Stick Shift = No PSE?
Using Porsche's online "Build Your Cayenne" I noticed that if I config a V6 with Manual Transmission and PASM that the Performance Sport Exhaust (PSE) selection does not appear. If I replace the manual transmission with 8 Speed Auto Transmission the PSE then appears. Does the PSE require the 8 speed Auto?! I know that you need PASM, which I did select with the manual transmission because the Sport selection is required for the exhaust but don't understand why you would need to 8 speed auto also for PSE. Is this an error with the online configurator?
Jul 29, 2019 11:13 AM
hyboost
Aug 24, 2015 01:45 PM
ppwchiang
Aug 20, 2015 10:28 AM
Aug 19, 2015 06:55 PM
