Steering Column Not Raising
Old Mar 3, 2013 | 04:43 PM
jesh's Avatar
jesh is infamous around these parts
Anybody have an issue with manually trying to raise the steering column? By manually, I mean with the switch under the column? It seems to go up when I park and turn off ignition, but trying to 'manually' move it isn't working...
Good news is, I drive with it all the way down (why DOES it go up so high, anyhow? Do people really sit that high up in this car?)
Old Mar 3, 2013 | 06:24 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
In sure you've done, but make sure you have comfort access off if you don't want it to move at all. And if that's not the issue make sure you re-save the settings with buttons on door linked to key.
Old Mar 3, 2013 | 07:59 PM
jesh's Avatar
No that isn't the problem. The problem is I can't get it to move up at all (e.g. I can't adjust it UP). It goes in and out, but not up and down anymore. But I know it CAN go up, because the comfort access raises it up like I want it.
I don't know if the switch is broken or what
Old Mar 3, 2013 | 09:04 PM
Jace's Avatar
Gotcha. Might be a switch fault.
Take er in.
Old Mar 4, 2013 | 03:10 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
how do you turn comfort access off? is it thru the steering wheel or pcm?
Kai@ELITEMS
996 Turbo Vendor Classifieds
Nov 25, 2015 06:44 AM
Kai@ELITEMS
997 Turbo Vendor Classifieds
Nov 25, 2015 06:39 AM
Kai@ELITEMS
996 Vendor Classifieds
Nov 25, 2015 06:32 AM
Kai@ELITEMS
997 Vendor Classifieds
kchu221
Oct 2, 2015 10:39 AM
