Cayenne non-Diesel has no self-locking center differential?
Old Mar 12, 2013 | 04:49 AM
Acc99's Avatar
Acc99 is infamous around these parts
Copied from another forum ...
It seems that the Cayenne Petrol (Base, S, GTS, Turbo and Turbo S) is more different than we think compared to a Cayenne Diesel and Hybrid.
The driveline differential for a Non Diesel Cayenne is apparently different from a Diesel Cayenne. Which one is better?
Here's how Porsche describes them:
For Cayenne/S, GTS, Turbo/S:
Porsche Traction Management (PTM): active all-wheel drive with electronic controlled, map-controlled multi-plate clutch, automatic limited-slip differential (ABD) and traction-slip control (ASR)
For Cayenne Diesel and Hybrid:
Porsche Traction Management (PTM): permanent all-wheel drive with self-locking center differential, variable rear torque split
Link below talks about driveline differential technologies.
http://www.audiworld.com/news/11/quattro-tech/ Questions for technical gear heads :
1. Simple question: For those with a Catenne V6, Cayenne S, GTS, Turbo/S, can you lock your center and rear differential via the control ****?
2. Complex question: Which driveline differential technology is better, the Diesel or Petrol? The self-locking center differential technology of the Diesel appears to be old technology from my (non expert) research.
3. Super complex question: is the presence of a self locking center diff (in the case of the Diesel) a core reason why PDCC is not offered on a Diesel vs a Non-Diesel? You can get PDCC only with non-diesel Cayenne's.
Would appreciate your help and comments on the two differential technologies.
Old Mar 16, 2013 | 06:20 PM
Sc00ter's Avatar
Sc00ter is infamous around these parts
V6, Cayenne S, GTS, Turbo/S does not come standard with a rear differential. If you want the rear differential you must take PTV option.
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
