3WD|BBS SV on Porsche Cayenne
Old Sep 24, 2014 | 12:05 PM
3WDistributing's Avatar
3WDistributing is a jewel in the rough3WDistributing is a jewel in the rough3WDistributing is a jewel in the rough3WDistributing is a jewel in the rough
BBS SV
20x10 +40
Black with Diamond Cut Face or Titanium
Fitment: All Cayenne Models
One Piece Counter Pressure Cast Wheel with Flow-formed rim - Spun inner rim using BBS Flow Forming Process - Weight optimized by FEM analysis
Please contact us for BEST member pricing.
Thank you!!!
3W Distributing LLC
5140 Rogers Street Ste C
Las Vegas, NV 89118
Website: www.3wdistributing.com
Facebook: 3wdistributing | Instagram: 3wdistributing
#1 BRABUS Dealer in North America | TECHART Authorized Dealer
Authorized Distributor for: BRABUS, TechArt, StarTech, BBS, Mansory, BREMBO, KW Suspension, H&R, Ohlins, FI Exhaust, and Much More....
WE SHIP WORLDWIDE....
Old Sep 24, 2014 | 08:02 PM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
Look great!
Maybe a dumb question: IIRC the offset should be at or near 50 on late model Cayenne/Touaregs 20x10 wheels.
What impact does 40 have? Need spacers?
Old Sep 24, 2014 | 08:43 PM
Originally Posted by BlazinPond
Look great!
Hello,
No spacers needed. The +40 are meant to clear any caliper issues the wheels may have. BBS designed these wheels to clear calipers for Turbo and Non Turbo models.
Thank you!
3W Distributing LLC
Las Vegas, NV 89118
Old Sep 25, 2014 | 06:22 PM
BlazinPond's Avatar
Originally Posted by 3WDistributing
Hello,
Thank you!
My question was less related to brake clearances and more about overall fitment.
Wheel offset is one of the most misunderstood and unknown things about car building. There's a lot more to it than just a number.
A misconception is that a higher offset number means more brake clearance. Brake clearance is determined by face and spoke design. You can have a +100 ET rim with a super-concave face that has no room for large calipers. Just the same, you can have a -100 ET rim with such a curved convex face, that it allows for large aftermarket calipers.
Anyways, your response is less than comforting that you understand the "offset" requirements for the Cayenne 20x10 wheel.
From what i understand, the Cayenne/Touareg should have an offset of 50 (ET50). Additionally, from what i understand, an average deviation of only 5mm is typically allowed or advised. (Please feel free to correct me if I'm wrong)
So, if the Cayenne 20x10 wheel calls for an offset of 50mm and yours is 40mm, it does not fit within the generally accepted deviation and therefore, not optimal.
Offset has a significant effect on many elements of a vehicle's suspension, including suspension geometry, clearance between the tire and suspension elements, the scrub radius of the steering system, and visually, the width of the wheel faces relative to the cars bodywork.
As a result, offset is important to get right.
I'm not trying to argue, just get the facts so that me or others can choose the right wheel size for aftermarket wheels.
Old Sep 26, 2014 | 10:26 AM
Hello again,
After carefully reading your concern, we had a concern of our own with these wheels so we contacted BBS directly to get an answer.
BBS told us that BBS Germany wanted these wheels to sit more aggressively so that's the reason why they offered a +40 offset. It was also stated that some of the cars "may" need fender modifications when running the these wheels.
Not all BBS wheels have aggressive fitment. Some of the 22" BBS wheels are +50 offset.
Please let us know if you have any more questions we can assist you with.
Thank you for your time.
3W Distributing LLC
Las Vegas, NV 89118
Old Oct 6, 2014 | 12:01 PM
Happy Monday!!
3W Distributing LLC
Las Vegas, NV 89118
Old Jun 16, 2016 | 05:30 PM
Summer Sale going on Now!!
3W Distributing LLC
Las Vegas, NV 89118
albert@velosdesignwerks
Cayenne
Aug 28, 2015 06:36 PM
Cayenne 958
Aug 19, 2015 02:43 PM
