Expedition Cayenne
Old Dec 28, 2014 | 06:57 AM
CRB357's Avatar
CRB357 is infamous around these parts
Why can't a simple 2" to 3" suspension/spring lift be used on a non Air Suspension Cayenne like on every other vehicle? I've been looking for a while now and have yet to see a regular suspension type (non spacer) lift on a Cayenne.
Old Dec 28, 2014 | 07:14 AM
dyim's Avatar
dyim is infamous around these parts
Wow. Good to see you guys using the 'U' in the SUV.
Old Dec 28, 2014 | 12:57 PM
mep1811's Avatar
mep1811 is infamous around these parts
Expo Cayenne
if you can find a suspension lift please let me know.
Old Dec 28, 2014 | 01:16 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
You guys might want to look into a suspension lift for the VW Touareg since it was built on the same chassis and those guys are more likely to go offroad.
Old Dec 28, 2014 | 04:32 PM
Moderator
Here you go, Suspension lift kit Touareg (+30mm):
http://www.seikel.de/en/products/seikel-vw-touareg/
Also, I say you guys stop beating around the bush and jump in with both feet :
Old Dec 28, 2014 | 05:05 PM
CRB357's Avatar
Thanks a bunch. So then this issue is really one of no after market for complete suspension lifts on the Cayenne, NOT an issue of it being technically impossible. 30mm is getting there. I'm going to try and call a few suspension places (Icon, Fox, King) and see if a custom spring can be made and used with an existing taller shock. Problem I see is that they will not be familiar with the Cayenne/Touareg, and will need a chassis to measure/eyeball.
Those two VW's are so awesome.
NC 996TT
Mar 23, 2023 06:19 AM
jonate24
Oct 25, 2015 11:34 AM
Oct 7, 2015 12:55 PM
