Anyone running wide tires on 22"?
Old Dec 4, 2014 | 05:10 PM
HOiYA's Avatar
HOiYA is infamous around these parts
I'm starting to look for some new tires and wanted to see what fellow 6speeders are running. I plan on running 22x10/22x10.5 wheels, unless someone can tell me running something wider is doable. I know some folks run 305 on their 955/957, but I wanted to hear of any 958 experiences. Please provide tire specs and tire brand/name.
So far I have seen:
  1. 295 x 30 x 22
  2. 305 x 35 x 22 (rubbing on turns?)
  3. 315 x 30 x 22 (probably would only work in a staggered setup)
  4. 335 x 25 x 22 (would require a 22x12 wheel)
TIA
Old Jan 19, 2015 | 10:02 PM
HOiYA's Avatar
I wanted to bump the thread and see if anyone has a square 305/35/22 setup. My wheels should be arriving in the next couple of weeks and I'm waffling between 295/30/22 and 305/35/22.
At first glance, the 305's are 32.4mm larger in diameter and 10mm wider and look doable. Anyone have any thoughts? Or better if you are currently running this config.
http://www.tacomaworld.com/forum/tir...5r21-305-35r22 TIA
Jul 29, 2019 11:13 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
FIRST_PORSCHE
Aug 30, 2015 11:00 AM
Zero911
Aug 24, 2015 06:51 PM
